Saltar al contenido principal
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: paso 2, imagen 1 de 2 Canon Powershot ELPH 100 HS Memory Card Replacement: paso 2, imagen 2 de 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 3 de 3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Conclusión
Lillia
Miembro Desde 03/17/15
267 Reputación
2 Guías creadas
Equipo
Un comentario
my internal card reader hardware is not functional
can i replace it somehow
s l - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 1,113
