Saltar al contenido principal
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: paso 1, imagen 1 de 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: paso 1, imagen 2 de 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: paso 2, imagen 1 de 2 Canon Powershot ELPH 100 HS Battery Replacement: paso 2, imagen 2 de 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Conclusión
Una persona más ha completado esta guía.
Lillia
Miembro Desde 03/17/15
255 Reputación
2 Guías creadas
Equipo
2 comentarios
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Contestar
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 58
Todo El Tiempo: 1,789
