Saltar al contenido principal
Canon Powershot A70 Speaker Replacement
Qué necesitas
  1. Canon Powershot A70 Speaker Replacement, Shutter/Speaker Panel: paso 1, imagen 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Speaker Replacement: paso 2, imagen 1 de 2 Canon Powershot A70 Speaker Replacement: paso 2, imagen 2 de 2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Speaker Replacement, Rear Exterior Panel: paso 3, imagen 1 de 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Speaker Replacement: paso 5, imagen 1 de 3 Canon Powershot A70 Speaker Replacement: paso 5, imagen 2 de 3 Canon Powershot A70 Speaker Replacement: paso 5, imagen 3 de 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Speaker Replacement: paso 6, imagen 1 de 2 Canon Powershot A70 Speaker Replacement: paso 6, imagen 2 de 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Speaker Replacement: paso 7, imagen 1 de 1
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Speaker Replacement, Front Exterior Panel: paso 8, imagen 1 de 1
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. Canon Powershot A70 Speaker Replacement: paso 9, imagen 1 de 2 Canon Powershot A70 Speaker Replacement: paso 9, imagen 2 de 2
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
  10. Canon Powershot A70 Speaker Replacement, Speakers: paso 10, imagen 1 de 1
    • Remove the two clearly visible screws from the control dial with a Phillips #00 screwdriver.
    • Remove the dial—it should come off easily.
  11. Canon Powershot A70 Speaker Replacement: paso 11, imagen 1 de 2 Canon Powershot A70 Speaker Replacement: paso 11, imagen 2 de 2
    • With tweezers, carefully unplug the two small wires from the green plug.
    • Carefully replace the broken speaker/shutter panel with a new one.
  12. Canon Powershot A70 Speaker Replacement: paso 12, imagen 1 de 1
    • The removed panel should look like this.
Conclusión
Una persona más ha completado esta guía.
Laura Greek
Miembro Desde 01/25/10
28 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-40, Regan Winter 2010 Miembro de Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,999
