Saltar al contenido principal
Canon Powershot A70 Rear Exterior Panel Replacement
Qué necesitas
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: paso 1, imagen 1 de 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: paso 2, imagen 1 de 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: paso 3, imagen 1 de 3 Canon Powershot A70 Rear Exterior Panel Replacement: paso 3, imagen 2 de 3 Canon Powershot A70 Rear Exterior Panel Replacement: paso 3, imagen 3 de 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: paso 4, imagen 1 de 2 Canon Powershot A70 Rear Exterior Panel Replacement: paso 4, imagen 2 de 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: paso 5, imagen 1 de 1
    • The interior of the camera should look like this.
Conclusión
Shalan Ertis
Miembro Desde 01/26/10
83 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 14-40, Regan Winter 2010 Miembro de Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 3,291
