Introducción
How to remove the front panel.
Partes
No se requieren partes.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment.
  2. Open the CF compartment and remove the top screw The panel, that holds the shutter button and zoom, will come off.
    • Open the CF compartment and remove the top screw
    • The panel, that holds the shutter button and zoom, will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Unscrew the three small screws on the bottom.
    • Unscrew the three small screws on the bottom.
    • remove the wrist strap
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Remove the screw in the CF compartment.
    • Remove the screw in the CF compartment.
  6. Open the rubber Digital AV Out compartment flap. Pry the battery with the IFIXIT opening tool. Carefully pull out the battery with two fingers.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with the IFIXIT opening tool.
    • Carefully pull out the battery with two fingers.
    • Unscrew the two screws that are now visible.
  7. Starting from the bottom, carefully pull the casing off. The casing will now pivot at the top.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  8. The interior of the camera should look like this.
    • The interior of the camera should look like this.
  9. Remove the two screws at the top of the battery compartment.
    • Remove the two screws at the top of the battery compartment.
  10. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
Conclusión
Una persona más ha completado esta guía.
Brian
Miembro Desde 26/01/10
69 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 14-40, Regan Winter 2010 Miembro de Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 3,977
