Saltar al contenido principal
Canon Powershot A3300 IS Motherboard Replacement
Qué necesitas
  1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Motherboard Replacement: paso 2, imagen 1 de 2 Canon Powershot A3300 IS Motherboard Replacement: paso 2, imagen 2 de 2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: paso 3, imagen 1 de 2 Canon Powershot A3300 IS Motherboard Replacement, Front Cover: paso 3, imagen 2 de 2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: paso 4, imagen 1 de 2 Canon Powershot A3300 IS Motherboard Replacement, Motherboard: paso 4, imagen 2 de 2
    • Remove the black cover to expose the motherboard.
  5. Canon Powershot A3300 IS Motherboard Replacement: paso 5, imagen 1 de 2 Canon Powershot A3300 IS Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the shutter button located at the top left of the camera.
    • This will expose the screws that need to be removed.
  6. Canon Powershot A3300 IS Motherboard Replacement: paso 6, imagen 1 de 1
    • Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
  7. Canon Powershot A3300 IS Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the 1.6mm screw at the top of the camera.
  8. Canon Powershot A3300 IS Motherboard Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to pull out brown flat flexible wires from their connection.
    • Remember to gently wiggle the wires from the connection since they are very fragile connectors.
  9. Canon Powershot A3300 IS Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the last 1.2mm screw to pull out the motherboard.
    • The motherboard should freely separate from the housing.
  10. Canon Powershot A3300 IS Motherboard Replacement: paso 10, imagen 1 de 3 Canon Powershot A3300 IS Motherboard Replacement: paso 10, imagen 2 de 3 Canon Powershot A3300 IS Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove motherboard and replace with a new one.
Conclusión
Phillip Chen
Miembro Desde 10/17/17
440 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 599
