Introducción
By fixing your flash, you can once again take bright, vibrant photographs.
Qué necesitas
To remove the battery, locate the battery cover on the bottom of the camera.
Using your thumb, press down on the cover and slide it outwards.
Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
Fix your Canon's flash in order to take bright, vibrant photographs.
Una persona más ha completado esta guía.
