Saltar al contenido principal
Canon PowerShot SX260 HS Battery Replacement
Qué necesitas
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot SX260 HS Battery Replacement: paso 2, imagen 2 de 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: paso 3, imagen 1 de 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Conclusión
Tyler Kelch
Miembro Desde 03/05/15
622 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,212
