Saltar al contenido principal
Canon PowerShot SX160 IS Outer Case Replacement
Qué necesitas
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: paso 1, imagen 1 de 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: paso 1, imagen 2 de 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: paso 1, imagen 3 de 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: paso 2, imagen 1 de 2 Canon PowerShot SX160 IS Outer Case Replacement: paso 2, imagen 2 de 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX160 IS Outer Case Replacement: paso 3, imagen 2 de 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
Conclusión
2 personas más completaron esta guía.
Jamie Secretan
Miembro Desde 03/11/15
1,990 Reputación
6 Guías creadas
Equipo
Un comentario
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 23
Todo El Tiempo: 1,966
