Saltar al contenido principal
Canon PowerShot SX160 IS LCD Replacement
Qué necesitas
  1. Canon PowerShot SX160 IS LCD Replacement, LCD: paso 1, imagen 1 de 3 Canon PowerShot SX160 IS LCD Replacement, LCD: paso 1, imagen 2 de 3 Canon PowerShot SX160 IS LCD Replacement, LCD: paso 1, imagen 3 de 3
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD Replacement: paso 2, imagen 1 de 2 Canon PowerShot SX160 IS LCD Replacement: paso 2, imagen 2 de 2
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX160 IS LCD Replacement: paso 3, imagen 2 de 2
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD Replacement: paso 4, imagen 1 de 1
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD Replacement: paso 5, imagen 1 de 1
    • Using your hand, pull the LCD screen away from the camera and replace.
Conclusión
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
2 personas más completaron esta guía.
Jamie Secretan
Miembro Desde 03/11/15
1,990 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 1,509
