Saltar al contenido principal
Canon PowerShot SX160 IS Function Wheel Replacement
Qué necesitas
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: paso 1, imagen 1 de 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: paso 1, imagen 2 de 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: paso 1, imagen 3 de 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: paso 2, imagen 1 de 2 Canon PowerShot SX160 IS Function Wheel Replacement: paso 2, imagen 2 de 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX160 IS Function Wheel Replacement: paso 3, imagen 2 de 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: paso 4, imagen 1 de 1
    • Remove and replace the function wheel.
Conclusión
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Miembro Desde 03/11/15
1,990 Reputación
6 Guías creadas
Equipo
Un comentario
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 620
