Saltar al contenido principal
Canon PowerShot SX160 IS Format Wheel Replacement
Qué necesitas
  1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: paso 1, imagen 1 de 2 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: paso 1, imagen 2 de 2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
    • The screws are located directly above the LCD screen.
  2. Canon PowerShot SX160 IS Format Wheel Replacement: paso 2, imagen 1 de 2 Canon PowerShot SX160 IS Format Wheel Replacement: paso 2, imagen 2 de 2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
  3. Canon PowerShot SX160 IS Format Wheel Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX160 IS Format Wheel Replacement: paso 3, imagen 2 de 2
    • Use your hands to gently separate the back plate from the camera.
    • Slowly pull off the camera plate until it fully detaches from the camera.
  4. Canon PowerShot SX160 IS Format Wheel Replacement: paso 4, imagen 1 de 2 Canon PowerShot SX160 IS Format Wheel Replacement: paso 4, imagen 2 de 2
    • Use your hands to gently separate the front plate from the camera.
  5. Canon PowerShot SX160 IS Format Wheel Replacement: paso 5, imagen 1 de 1
    • Locate and replace the format wheel on the front panel of the camera.
Conclusión
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Miembro Desde 03/11/15
1,962 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 665
