Saltar al contenido principal
Canon PowerShot SX150 IS Prerequisite
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Canon PowerShot SX150 IS Prerequisite, Canon PowerShot SX150 IS Prerequisite: paso 1, imagen 1 de 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  2. Canon PowerShot SX150 IS Prerequisite: paso 2, imagen 1 de 2 Canon PowerShot SX150 IS Prerequisite: paso 2, imagen 2 de 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  3. Canon PowerShot SX150 IS Prerequisite: paso 3, imagen 1 de 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  4. Canon PowerShot SX150 IS Prerequisite: paso 4, imagen 1 de 1
    • Remove the plastic panel surrounding the back screen.
  5. Canon PowerShot SX150 IS Prerequisite: paso 5, imagen 1 de 3 Canon PowerShot SX150 IS Prerequisite: paso 5, imagen 2 de 3 Canon PowerShot SX150 IS Prerequisite: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  6. Canon PowerShot SX150 IS Prerequisite: paso 6, imagen 1 de 2 Canon PowerShot SX150 IS Prerequisite: paso 6, imagen 2 de 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  7. Canon PowerShot SX150 IS Prerequisite: paso 7, imagen 1 de 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  8. Canon PowerShot SX150 IS Prerequisite: paso 8, imagen 1 de 3 Canon PowerShot SX150 IS Prerequisite: paso 8, imagen 2 de 3 Canon PowerShot SX150 IS Prerequisite: paso 8, imagen 3 de 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  9. Canon PowerShot SX150 IS Prerequisite: paso 9, imagen 1 de 2 Canon PowerShot SX150 IS Prerequisite: paso 9, imagen 2 de 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  10. Canon PowerShot SX150 IS Prerequisite: paso 10, imagen 1 de 3 Canon PowerShot SX150 IS Prerequisite: paso 10, imagen 2 de 3 Canon PowerShot SX150 IS Prerequisite: paso 10, imagen 3 de 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 8
Todo El Tiempo: 124
