Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will take you through the steps needed to replace the Digital Image Sensor in your Cannon PowerShotSX150 IS. This can be used to fix blurry images if your problem appears to be the Digital Image Sensor.
  1. Locate the battery cover on the bottom of the camera. Slide the battery compartment cover the direction the arrow is pointing to open the compartment. Remove batteries.
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Remove the two 2mm screws above the screen using the size J000 screwdriver.
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Remove the two 5mm screws from the side of the camera with the J000 head screw driver. Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Remove the plastic panel surrounding the back screen.
    • Remove the plastic panel surrounding the back screen.
  6. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  7. Remove the three 3mm screws using the size J000 screw driver from the button plate. Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers. Move the button plate out of the way.
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  8. There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach. Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  9. Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  10. With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash. Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door. With the same screwdriver, remove the 2mm screw at the top of the metal plate.
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  11. Gently detach the flex ribbon with your tweezers before removing the front plate. Gently detach the flex ribbon with your tweezers before removing the front plate.
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  12. Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel. Remove the two 5mm screws. Remove the one 3 mm screw.
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  13. Lift the two flex ribbons with your tweezers and remove them. Move the circuit board to the side.
    • Lift the two flex ribbons with your tweezers and remove them.
    • Move the circuit board to the side.
  14. Remove the three 2 mm screws from around the sensor. Pull the sensor away.
    • Remove the three 2 mm screws from around the sensor.
    • Pull the sensor away.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 521
