Introducción
This guide will show you how to replace the buttons on your Canon Powershot SX150 IS. You can use this guide if any of your buttons no longer work.
Qué necesitas
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
Un comentario
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
