Saltar al contenido principal
Canon PowerShot SX120 IS Control Dial Replacement
Qué necesitas
  1. Canon PowerShot SX120 IS Control Dial Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Control Dial Replacement: paso 2, imagen 1 de 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Control Dial Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX120 IS Control Dial Replacement: paso 3, imagen 2 de 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Control Dial Replacement: paso 4, imagen 1 de 2 Canon PowerShot SX120 IS Control Dial Replacement: paso 4, imagen 2 de 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Control Dial Replacement: paso 5, imagen 1 de 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Control Dial Replacement: paso 6, imagen 1 de 3 Canon PowerShot SX120 IS Control Dial Replacement: paso 6, imagen 2 de 3 Canon PowerShot SX120 IS Control Dial Replacement: paso 6, imagen 3 de 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Control Dial Replacement: paso 7, imagen 1 de 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
  8. Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: paso 8, imagen 1 de 3 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: paso 8, imagen 2 de 3 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
    • Use a pair of tweezers to remove the old control dial and set the new control in the same place.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 1,468
