Saltar al contenido principal
Canon PowerShot SD960 IS Battery Replacement
  1. Canon PowerShot SD960 IS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD960 IS Battery Replacement: paso 2, imagen 2 de 2
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS Battery Replacement: paso 3, imagen 1 de 1
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 462
