Saltar al contenido principal
Canon PowerShot SD850 IS Function Set Button Replacement
Qué necesitas
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: paso 1, imagen 1 de 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: paso 1, imagen 2 de 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: paso 1, imagen 3 de 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD850 IS Function Set Button Replacement: paso 2, imagen 2 de 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: paso 3, imagen 1 de 2 Canon PowerShot SD850 IS Function Set Button Replacement, Case: paso 3, imagen 2 de 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: paso 4, imagen 1 de 3 Canon PowerShot SD850 IS Function Set Button Replacement: paso 4, imagen 2 de 3 Canon PowerShot SD850 IS Function Set Button Replacement: paso 4, imagen 3 de 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: paso 5, imagen 1 de 2 Canon PowerShot SD850 IS Function Set Button Replacement: paso 5, imagen 2 de 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: paso 6, imagen 1 de 2 Canon PowerShot SD850 IS Function Set Button Replacement: paso 6, imagen 2 de 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: paso 7, imagen 1 de 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: paso 8, imagen 1 de 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: paso 9, imagen 1 de 2 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: paso 9, imagen 2 de 2
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: paso 10, imagen 1 de 1
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: paso 11, imagen 1 de 1
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
Conclusión
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,169
