Saltar al contenido principal
Canon PowerShot SD850 IS Camera Lens Replacement
Qué necesitas
  1. Canon PowerShot SD850 IS Camera Lens Replacement, Case: paso 1, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement, Case: paso 1, imagen 2 de 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  2. Canon PowerShot SD850 IS Camera Lens Replacement: paso 2, imagen 1 de 3 Canon PowerShot SD850 IS Camera Lens Replacement: paso 2, imagen 2 de 3 Canon PowerShot SD850 IS Camera Lens Replacement: paso 2, imagen 3 de 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  3. Canon PowerShot SD850 IS Camera Lens Replacement: paso 3, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 3, imagen 2 de 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  4. Canon PowerShot SD850 IS Camera Lens Replacement: paso 4, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 4, imagen 2 de 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  5. Canon PowerShot SD850 IS Camera Lens Replacement: paso 5, imagen 1 de 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  6. Canon PowerShot SD850 IS Camera Lens Replacement: paso 6, imagen 1 de 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  7. Canon PowerShot SD850 IS Camera Lens Replacement, LCD Screen: paso 7, imagen 1 de 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  8. Canon PowerShot SD850 IS Camera Lens Replacement: paso 8, imagen 1 de 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  9. Canon PowerShot SD850 IS Camera Lens Replacement: paso 9, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 9, imagen 2 de 2
    • Remove the two metal frames that hold the LCD panel in place.
  10. Canon PowerShot SD850 IS Camera Lens Replacement: paso 10, imagen 1 de 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  11. Canon PowerShot SD850 IS Camera Lens Replacement: paso 11, imagen 1 de 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  12. Canon PowerShot SD850 IS Camera Lens Replacement: paso 12, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 12, imagen 2 de 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD850 IS Camera Lens Replacement, Flash Unit: paso 13, imagen 1 de 1
    • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
  14. Canon PowerShot SD850 IS Camera Lens Replacement: paso 14, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 14, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
    • Next use the tweezers to carefully remove the speaker cable off its respective holders.
  15. Canon PowerShot SD850 IS Camera Lens Replacement: paso 15, imagen 1 de 1
    • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
  16. Canon PowerShot SD850 IS Camera Lens Replacement: paso 16, imagen 1 de 2 Canon PowerShot SD850 IS Camera Lens Replacement: paso 16, imagen 2 de 2
    • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
    • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
  17. Canon PowerShot SD850 IS Camera Lens Replacement: paso 17, imagen 1 de 1
    • Gently remove the flash component from the rest of the camera.
    • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
  18. Canon PowerShot SD850 IS Camera Lens Replacement, Camera Lens: paso 18, imagen 1 de 1
    • Remove four screws located on the back of the camera:
    • 6.15 mm #00 Phillips
    • 2.75 mm #00 Phillips
    • 2.15 mm #00 Phillips
    • 2.7 mm #00 Phillips
  19. Canon PowerShot SD850 IS Camera Lens Replacement: paso 19, imagen 1 de 1
    • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
  20. Canon PowerShot SD850 IS Camera Lens Replacement: paso 20, imagen 1 de 1
    • Gently remove the camera lens from the rest of the camera.
Conclusión
3 personas más completaron esta guía.
Peter Tran
Miembro Desde 10/06/10
225 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 20-7, Maness Fall 2010 Miembro de Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Miembros
7 Guías creadas
Un comentario
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
Jerome Tenedero - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 28
Todo El Tiempo: 14,381
