Saltar al contenido principal
Canon PowerShot SD700 E18 Error Replacement
Qué necesitas
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: paso 1, imagen 1 de 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: paso 2, imagen 1 de 1
    • Remove the two small screws on the bottom of the camera using a Phillips #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: paso 6, imagen 1 de 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Herramienta utilizada en este paso:
    Dust Blower
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
Conclusión
To reassemble your device, follow steps 1-6 instructions in reverse order.
Una persona más ha completado esta guía.
Aaron Lee
Miembro Desde 04/07/11
212 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-71, Walters Spring 2011 Miembro de Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 21
Todo El Tiempo: 3,151
