Saltar al contenido principal
Canon PowerShot SD700 Backlight Replacement
Qué necesitas
  1. Canon PowerShot SD700 Backlight Replacement, Outside Case: paso 1, imagen 1 de 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 Backlight Replacement: paso 2, imagen 1 de 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 Backlight Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 Backlight Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 Backlight Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 Backlight Replacement: paso 6, imagen 1 de 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 Backlight Replacement, LCD screen: paso 7, imagen 1 de 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 Backlight Replacement: paso 8, imagen 1 de 3 Canon PowerShot SD700 Backlight Replacement: paso 8, imagen 2 de 3 Canon PowerShot SD700 Backlight Replacement: paso 8, imagen 3 de 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 Backlight Replacement: paso 9, imagen 1 de 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
  10. Canon PowerShot SD700 Backlight Replacement, Backlight: paso 10, imagen 1 de 1
    • Unplug the ribbon from the housing on the circuitry.
    • Take the new ribbon and insert it into the housing.
    • Tweezers or a tool with a sharp point can be used.
Conclusión
Emilio Rossi
Miembro Desde 04/07/11
113 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 9-71, Walters Spring 2011 Miembro de Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 1,617
