Saltar al contenido principal
Canon PowerShot SD500 Digital ELPH Image Sensor Replacement
Qué necesitas
  1. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Battery: paso 1, imagen 1 de 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 2, imagen 2 de 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: paso 3, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Front and Rear Casing: paso 3, imagen 2 de 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 4, imagen 1 de 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 5, imagen 1 de 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 6, imagen 1 de 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 7, imagen 1 de 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 8, imagen 1 de 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 9, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 9, imagen 2 de 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Button Contact Panel: paso 10, imagen 1 de 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 11, imagen 1 de 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 12, imagen 1 de 3 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 12, imagen 2 de 3 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 12, imagen 3 de 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, LCD: paso 13, imagen 1 de 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 14, imagen 1 de 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 15, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 15, imagen 2 de 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement, Image Sensor: paso 16, imagen 1 de 1
    • Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
  17. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 17, imagen 1 de 1
    • Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
  18. Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 18, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Image Sensor Replacement: paso 18, imagen 2 de 2
    • Use the pry tool to gently lift the image sensor away from the rest of the camera.
    • Be careful not to damage the image sensor as you pry it up.
Conclusión
Taylor Shields
Miembro Desde 10/13/14
846 Reputación
8 Guías creadas
Equipo
Clemson, Team 2-1, Benson Fall 2014 Miembro de Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 271
