Introducción
Removing the LCD screen for replacement.
Qué necesitas
Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
4 personas más completaron esta guía.
3 comentarios
Salve, dove posso acquistare un display?
Salve, sapreste dirmi dove posso acquistare un display?
