Saltar al contenido principal
Canon PowerShot SD1400 IS User Interface Panel Replacement
Qué necesitas
  1. Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: paso 1, imagen 1 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: paso 1, imagen 2 de 3 Canon PowerShot SD1400 IS User Interface Panel Replacement, User Interface Panel: paso 1, imagen 3 de 3
    • Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
  2. Canon PowerShot SD1400 IS User Interface Panel Replacement: paso 2, imagen 1 de 1
    • Remove the 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS User Interface Panel Replacement: paso 3, imagen 1 de 1
    • Remove the front face panel of the camera by hand using firm pressure.
    • If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
  4. Canon PowerShot SD1400 IS User Interface Panel Replacement: paso 4, imagen 1 de 1
    • Remove the rear panel of the camera by hand using firm pressure.
  5. Canon PowerShot SD1400 IS User Interface Panel Replacement: paso 5, imagen 1 de 1
    • Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
    • Replace the user interface panel by setting it in position.
Conclusión
2 personas más completaron esta guía.
Braxton Beal
Miembro Desde 01/30/18
702 Reputación
3 Guías creadas
Equipo
Baylor, Team S1-G3, Johnson Spring 2018 Miembro de Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 325
