Saltar al contenido principal
Canon PowerShot SD1400 IS Battery Replacement
Qué necesitas
  1. Canon PowerShot SD1400 IS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • The battery compartment is located on the bottom of the camera, below the user interface panel.
  2. Canon PowerShot SD1400 IS Battery Replacement: paso 2, imagen 1 de 1
    • The hatch covering the memory card will slide open towards the corner of the device.
  3. Canon PowerShot SD1400 IS Battery Replacement: paso 3, imagen 1 de 1
    • Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
  4. Canon PowerShot SD1400 IS Battery Replacement: paso 4, imagen 1 de 1
    • Once open, you will see a small orange tab near the corner of the camera.
    • Push this tab towards the front face of the device, and the battery will freely fall out from the hatch.
Conclusión
3 personas más completaron esta guía.
Matt Holquist
Miembro Desde 02/01/18
157 Reputación
1 Guía escrita
Equipo
Baylor, Team S1-G3, Johnson Spring 2018 Miembro de Baylor, Team S1-G3, Johnson Spring 2018
BU-JOHNSON-S18S1G3
Miembros de 3
4 Guías creadas
Un comentario
Where do I go to pay?
drdenny46 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 48
Todo El Tiempo: 1,734
