Saltar al contenido principal
Canon PowerShot SD1200 IS Motherboard
Qué necesitas
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: paso 1, imagen 1 de 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: paso 2, imagen 1 de 3 Canon PowerShot SD1200 IS Motherboard: paso 2, imagen 2 de 3 Canon PowerShot SD1200 IS Motherboard: paso 2, imagen 3 de 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: paso 3, imagen 1 de 2 Canon PowerShot SD1200 IS Motherboard: paso 3, imagen 2 de 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: paso 4, imagen 1 de 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: paso 5, imagen 1 de 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: paso 6, imagen 1 de 2 Canon PowerShot SD1200 IS Motherboard: paso 6, imagen 2 de 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: paso 7, imagen 1 de 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: paso 8, imagen 1 de 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: paso 9, imagen 1 de 1
    • Lift out the motherboard.
Conclusión
Jeff Casper
Miembro Desde 09/15/16
860 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 17-5, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 480
