Introducción
Damaging the lens on your camera can be a death sentence. But never fear, if you have an old compatible Canon camera you can cannibalize, or find a good part elsewhere, restoring your camera to working order is relatively simple.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Use the spudger to lift the retaining flap on the Zero Insertion Force (ZIF) tab securing the thick ribbon cable.
Slide out the ribbon cable using fingers or tweezers.
Using tweezers, disconnect the small ribbon cable below the flash assembly from the No Fuss Connector by simply pulling the ribbon cable straight out.
Use the spudger to pry up each side of the lens assembly Flat-Topped Connector at the bottom of the motherboard.
Holding back the lens assembly ribbon cable, use the spudger to lift the Zero Insertion Force (ZIF) connector tab . Slide out the ribbon cable.
Use the spudger to lift the Zero Insertion Force (ZIF) connector tab located on the flash unit. Remove the ribbon cable.
Use the spudger to gently pry up both sides of the flat-topped connector, then lift the cable directly up out of its socket.
5 personas más completaron esta guía.
2Guía Comentarios
i have this same camera, and for me all the sudden it stopped focasing completely. everything else works, and it isnt in any weird modes. when i try to focas especially on auto focas with the half button push, i hear some abnormal clicking like it is trying to auto focas but cant. im not sure what to do!
