Saltar al contenido principal
Canon PowerShot SD1200 IS Function Button Board Replacement
Qué necesitas
  1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: paso 1, imagen 1 de 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Function Button Board Replacement: paso 2, imagen 1 de 3 Canon PowerShot SD1200 IS Function Button Board Replacement: paso 2, imagen 2 de 3 Canon PowerShot SD1200 IS Function Button Board Replacement: paso 2, imagen 3 de 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Function Button Board Replacement: paso 3, imagen 1 de 2 Canon PowerShot SD1200 IS Function Button Board Replacement: paso 3, imagen 2 de 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: paso 4, imagen 1 de 1
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable from the connector.
  5. Canon PowerShot SD1200 IS Function Button Board Replacement: paso 5, imagen 1 de 1
    • Remove the top screw from the function button board. (3.5mm Phillips 00)
    • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
  6. Canon PowerShot SD1200 IS Function Button Board Replacement: paso 6, imagen 1 de 1
    • Lift out the function button board.
Conclusión
Jeff Casper
Miembro Desde 09/15/16
848 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 17-5, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 257
