Saltar al contenido principal
Canon PowerShot SD1100 IS Top Button Assembly Replacement
Qué necesitas
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: paso 1, imagen 1 de 2 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: paso 1, imagen 2 de 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 4, imagen 1 de 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: paso 5, imagen 1 de 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 6, imagen 1 de 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 8, imagen 1 de 1
    • The shutter button assembly should now be removed.
Conclusión
Una persona más ha completado esta guía.
Wyatt Chan
Miembro Desde 01/05/11
235 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,169
