Saltar al contenido principal
Canon PowerShot SD1000 Shutter Button Replacement
Qué necesitas
  1. Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: paso 1, imagen 1 de 2 Canon PowerShot SD1000 Shutter Button Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Shutter Button Replacement: paso 2, imagen 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Shutter Button Replacement: paso 3, imagen 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Shutter Button Replacement: paso 4, imagen 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Shutter Button Replacement: paso 5, imagen 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Shutter Button Replacement, Front Case: paso 6, imagen 1 de 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Shutter Button Replacement: paso 7, imagen 1 de 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: paso 8, imagen 1 de 2 Canon PowerShot SD1000 Shutter Button Replacement, Shutter Button: paso 8, imagen 2 de 2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
Conclusión
Phillip Phung
Miembro Desde 01/19/12
651 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 8-18, Maness Winter 2012 Miembro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 1,207
