Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PowerShot S500 Breakdown to Three Parts Replacement
Qué necesitas
  1. Canon PowerShot S500 Breakdown to Three Parts Replacement, Front and Rear Casing : paso 1, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement, Front and Rear Casing : paso 1, imagen 2 de 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
    Pregunta a FixBot
    Agregar Comentario
  2. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 2, imagen 1 de 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
    Pregunta a FixBot
    Agregar Comentario
  3. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 3, imagen 1 de 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
    Pregunta a FixBot
    Agregar Comentario
  4. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 4, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 4, imagen 2 de 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  5. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 5, imagen 1 de 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
    Pregunta a FixBot
    Agregar Comentario
  6. Canon PowerShot S500 Breakdown to Three Parts Replacement, LCD: paso 6, imagen 1 de 1
    • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  7. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 7, imagen 1 de 1
    • Gently separate the top of LCD from the rest of the camera using your thumb.
    • Be careful not pull the LCD too far because of the ribbon cable connection.
    • Place the Spudger in the hole of the electrical ribbon.
    • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
    • The LCD will still be connected to the rest of the camera
    Pregunta a FixBot
    Agregar Comentario
  8. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 8, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 8, imagen 2 de 2
    • Unscrew single Phillips screw with a #0 Phillips screwdriver.
    • Free the bottom panel and attached ribbon from the rest of the camera.
    • Be careful not to damage the ribbon.
    Pregunta a FixBot
    Agregar Comentario
  9. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 9, imagen 1 de 1
    • Turn over the camera.
    • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
    • The plastic will still be connected on the left side.
    Pregunta a FixBot
    Agregar Comentario
  10. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 10, imagen 1 de 1
    • Place the Spudger between the orange ribbon and the black ribbon gate.
    • Lift the ribbon gate using the Spudger.
    Pregunta a FixBot
    Agregar Comentario
  11. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 11, imagen 1 de 1
    • Place the Spudger in the corner of the ribbon above the hole.
    • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
    Pregunta a FixBot
    Agregar Comentario
  12. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 12, imagen 1 de 1
    • Free this ribbon and the bottom panel from the rest of the camera.
    Pregunta a FixBot
    Agregar Comentario
  13. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 13, imagen 1 de 1
    • Turn the camera over so you can see the LCD.
    • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  14. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 14, imagen 1 de 1
    • Lift the blue ribbon gate using the Spudger.
    Pregunta a FixBot
    Agregar Comentario
  15. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 15, imagen 1 de 1
    • Insert the Spudger into the hole of the ribbon.
    • Move the Spudger away from the gate to fully remove ribbon.
    Pregunta a FixBot
    Agregar Comentario
  16. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 16, imagen 1 de 1
    • Lift the LCD away from the rest of the camera.
    Pregunta a FixBot
    Agregar Comentario
  17. Canon PowerShot S500 Breakdown to Three Parts Replacement, Logic Board: paso 17, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement, Logic Board: paso 17, imagen 2 de 2
    • Lift off the capture button by wiggling it back and forth while pulling upward.
    • Be careful not to damage the two clips.
    Pregunta a FixBot
    Agregar Comentario
  18. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 18, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 18, imagen 2 de 2
    • Flip open the four ribbon gates using the Spudger.
    • Gently pull out the ribbon cables from the gates using the Spudger.
    Pregunta a FixBot
    Agregar Comentario
  19. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 19, imagen 1 de 1
    • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  20. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 20, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 20, imagen 2 de 2
    • Gently lift the logic board.
    • Be careful not to pull too hard and damage the white ribbon cable.
    • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
    • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
    Pregunta a FixBot
    Agregar Comentario
  21. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 21, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Lay the logic board back down so that it is resting on the body of the camera.
    • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
    Pregunta a FixBot
    Agregar Comentario
  22. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 22, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 22, imagen 2 de 2
    • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
    • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
    • Desolder the two soldered ribbon cables attached to the logic board.
    Pregunta a FixBot
    Agregar Comentario
  23. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 23, imagen 1 de 1
    • Free the logic board from the rest of the camera.
    Pregunta a FixBot
    Agregar Comentario
  24. Canon PowerShot S500 Breakdown to Three Parts Replacement, Breakdown to Three Parts: paso 24, imagen 1 de 1
    • Turn the camera over so that the back is facing you.
    • Unscrew the three Phillips screws using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  25. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 25, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 25, imagen 2 de 2
    • Lift off the Memory Card casing, sliding the ribbon cable through the camera. Keep pulling until the Memory Card and ribbon cable have been removed from the camera.
    • Note that the ribbon cable is coming from the external front portion of the camera. Make sure that the ribbon cable will not get caught on anything.
    Pregunta a FixBot
    Agregar Comentario
  26. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 26, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 26, imagen 2 de 2
    • Unscrew one Phillips screws from the side and three Phillips screws from the back panel using a #0 Phillips screwdriver.
    Pregunta a FixBot
    Agregar Comentario
  27. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 27, imagen 1 de 3 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 27, imagen 2 de 3 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 27, imagen 3 de 3
    • Firmly push on the back of the zoom lens, removing it from the left portion of the camera.
    • Lift the zoom lens away from the left portion of the camera so that there are three components connected by a ribbon cables.
    • Be careful not to tear the ribbon cables.
    Pregunta a FixBot
    Agregar Comentario
  28. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 28, imagen 1 de 1
    • The camera should now be able to be set in this orientation without too much stress on the cables.
    • The clear plastic is still attached to the battery casing.
    Pregunta a FixBot
    Agregar Comentario
  29. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 29, imagen 1 de 2 Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 29, imagen 2 de 2
    • Locate the ribbon cable going from the battery case to the flash assembly.
    • Remove the plug from the ribbon cable using the tweezers.
    • The flash assembly is now free from the rest of the camera.
    Pregunta a FixBot
    Agregar Comentario
  30. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 30, imagen 1 de 1
    • Pick up the remaining battery casing and zoom lens.
    • Pull off the clear plastic.
    • The clear plastic is secured by adhesive along the bottom edge and a small hook.
    Pregunta a FixBot
    Agregar Comentario
  31. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 31, imagen 1 de 1
    • Lift the zoom lens off of the battery casing.
    • The back of the circuits are attached to the battery casing by a light adhesive, which can be removed with a slight pull upwards.
    Pregunta a FixBot
    Agregar Comentario
  32. Canon PowerShot S500 Breakdown to Three Parts Replacement: paso 32, imagen 1 de 1
    • The remaining pieces from left to right are: the battery casing, zoom lens and flash assembly.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
Nathan Balcom
Miembro Desde 01/21/10
102 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 16-28, Maness Winter 2010 Miembro de Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
Miembros de 4
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 51
Todo El Tiempo: 3,388
