Saltar al contenido principal
Canon PowerShot S50 Right Motherboard Replacement
Qué necesitas
  1. Canon PowerShot S50 Right Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Canon PowerShot S50 Right Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Canon PowerShot S50 Right Motherboard Replacement: paso 2, imagen 1 de 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Canon PowerShot S50 Right Motherboard Replacement: paso 3, imagen 1 de 2 Canon PowerShot S50 Right Motherboard Replacement: paso 3, imagen 2 de 2
    • Holding the edges, slide out the battery.
  4. Canon PowerShot S50 Right Motherboard Replacement, Front Panel/Battery Door: paso 4, imagen 1 de 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Canon PowerShot S50 Right Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Canon PowerShot S50 Right Motherboard Replacement: paso 6, imagen 1 de 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Canon PowerShot S50 Right Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Canon PowerShot S50 Right Motherboard Replacement: paso 8, imagen 1 de 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Canon PowerShot S50 Right Motherboard Replacement: paso 9, imagen 1 de 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Canon PowerShot S50 Right Motherboard Replacement: paso 10, imagen 1 de 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Canon PowerShot S50 Right Motherboard Replacement: paso 11, imagen 1 de 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Canon PowerShot S50 Right Motherboard Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Canon PowerShot S50 Right Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Canon PowerShot S50 Right Motherboard Replacement, Right Motherboard: paso 14, imagen 1 de 1
    • Disconnect the two plastic ribbons on the lower half of the right motherboard.
    • NOTE: You will have to lift up the brown plastic piece in order to pull out the second ribbon wire.
  15. Canon PowerShot S50 Right Motherboard Replacement: paso 15, imagen 1 de 1
    • Remove the two 3.4mm screws on the right motherboard.
  16. Canon PowerShot S50 Right Motherboard Replacement: paso 16, imagen 1 de 1
    • Disconnect the two wired plugs below the flash.
  17. Canon PowerShot S50 Right Motherboard Replacement: paso 17, imagen 1 de 1
    • Disconnect the wired plug at the bottom of the right motherboard.
  18. Canon PowerShot S50 Right Motherboard Replacement: paso 18, imagen 1 de 1
    Comprar
    • Use a pair of tweezers to pull the right motherboard away from the main body of the camera.
Conclusión
2 personas más completaron esta guía.
Jacob
Miembro Desde 03/29/12
13 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-34, Maness Spring 2012 Miembro de Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,153
