Introducción
This guide will show you how to remove and replace the button panel on the top of the camera.
Qué necesitas
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Using your fingernail, gently pry up the clip holding the button panel in place along the side of the camera.
Una persona más ha completado esta guía.
