Saltar al contenido principal
Canon PowerShot S410 Battery Replacement
  1. Canon PowerShot S410 Battery Replacement, Battery: paso 1, imagen 1 de 2 Canon PowerShot S410 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon PowerShot S410 Battery Replacement: paso 2, imagen 1 de 1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon PowerShot S410 Battery Replacement: paso 3, imagen 1 de 2 Canon PowerShot S410 Battery Replacement: paso 3, imagen 2 de 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
Conclusión
After a new battery has been inserted, close the swinging door and you're done. Take your e-waste to an R2 or e-Stewards certified recycler.
Una persona más ha completado esta guía.
Randy Lormand
Miembro Desde 01/23/11
349 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-27, Maness Winter 2011 Miembro de Cal Poly, Team 11-27, Maness Winter 2011
CPSU-MANESS-W11S11G27
4 Miembros
7 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,769
