Saltar al contenido principal
Canon PowerShot S230 Display Screen Replacement
Qué necesitas
  1. Canon PowerShot S230 Display Screen Replacement, Display Screen: paso 1, imagen 1 de 1
    • Using a Phillips #0 head screwdriver, remove the screws on the outside casing of the camera.
  2. Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 1 de 3 Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 2 de 3 Canon PowerShot S230 Display Screen Replacement: paso 2, imagen 3 de 3
    • Use a pry tool to open the outer casing of the camera and access the internal components.
  3. Canon PowerShot S230 Display Screen Replacement: paso 3, imagen 1 de 2 Canon PowerShot S230 Display Screen Replacement: paso 3, imagen 2 de 2
    • Remove the metal shield and screws from the bottom interior of the camera.
  4. Canon PowerShot S230 Display Screen Replacement: paso 4, imagen 1 de 1
    • Use the Phillips head screwdriver to remove the screws securing the screen.
  5. Canon PowerShot S230 Display Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screws on the copper facing from the front part of the camera. Beneath is a connection to the screen. Wiggle this connection to pull it out; it may take some force to do so.
Conclusión
Will Appleton
Miembro Desde 05/31/16
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 276
