Saltar al contenido principal
Introducción
The LCD screen of the Camera is important to see what exactly the pictures you took look like. The purpose of this replacement guide is to help you remove the camera's LCD screen.
  1. Remove the four 2mm Phillips screws from the back of the screen.
    • Remove the four 2mm Phillips screws from the back of the screen.
  2. Remove the six 2mm Phillips #000 around the edge of the screen. Remove the six 2mm Phillips #000 around the edge of the screen. Remove the six 2mm Phillips #000 around the edge of the screen.
    • Remove the six 2mm Phillips #000 around the edge of the screen.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Using the plastic opening tool, pry back the backplate from the front of the screen. Using the plastic opening tool, pry back the backplate from the front of the screen. Using the plastic opening tool, pry back the backplate from the front of the screen.
    • Using the plastic opening tool, pry back the backplate from the front of the screen.
  5. Using the black nylon spudger, gently remove the ribbon cable. Remove the LCD screen.
    • Using the black nylon spudger, gently remove the ribbon cable.
    • Remove the LCD screen.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 10
Últimos 30 Días: 58
Todo El Tiempo: 708
