Saltar al contenido principal
Canon PowerShot G7X Dial Replacement
Qué necesitas
  1. Canon PowerShot G7X Dial Replacement, Dial: paso 1, imagen 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: paso 2, imagen 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: paso 3, imagen 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: paso 4, imagen 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: paso 5, imagen 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: paso 6, imagen 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: paso 7, imagen 1 de 2 Canon PowerShot G7X Dial Replacement: paso 7, imagen 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
Conclusión
Un comentario
Good guide. If you need to repair the jog dial, check this video for an excellent guide: https://www.youtube.com/watch?v=amuCb5ko...
jnbruin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 598
