Saltar al contenido principal
Canon PowerShot G1 X Screen Casing Replacement
Qué necesitas
  1. Canon PowerShot G1 X Screen Casing Replacement, Screen Casing: paso 1, imagen 1 de 1
    • Remove the screws on the outside of the screen case shown in the photo.
  2. Canon PowerShot G1 X Screen Casing Replacement: paso 2, imagen 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: paso 2, imagen 2 de 2
    • Remove the screws on the side of the screen casing next to the hinge on the camera.
  3. Canon PowerShot G1 X Screen Casing Replacement: paso 3, imagen 1 de 1
    • Remove the back side of the screen casing. When removing this back casing there will be a clear plastic piece inside, remove this as well. If this is the piece you are servicing, replace it and skip to the conclusion of this guide.
  4. Canon PowerShot G1 X Screen Casing Replacement: paso 4, imagen 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: paso 4, imagen 2 de 2
    • With the plastic piece removed, locate the screws on the outside and inside of the casing shown in the photos. Remove these screws.
  5. Canon PowerShot G1 X Screen Casing Replacement: paso 5, imagen 1 de 1
    • Locate the four clips on the metal piece covering the back of the screen as seen in the photo. Push each of these clips in towards the center of the piece and pull up on the metal plate.
  6. Canon PowerShot G1 X Screen Casing Replacement: paso 6, imagen 1 de 2 Canon PowerShot G1 X Screen Casing Replacement: paso 6, imagen 2 de 2
    • Completely remove the casing from the screen and replace.
Conclusión
Joseph Cosgrove
Miembro Desde 02/12/17
313 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 20-1, Remmell Spring 2017 Miembro de USF Tampa, Team 20-1, Remmell Spring 2017
USFT-REMMELL-S17S20G1
Miembros de 3
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 598
