Saltar al contenido principal
Canon PowerShot G1 X Mark II Battery Replacement
Qué necesitas
  1. Canon PowerShot G1 X Mark II Battery Replacement, Battery: paso 1, imagen 1 de 3 Canon PowerShot G1 X Mark II Battery Replacement, Battery: paso 1, imagen 2 de 3 Canon PowerShot G1 X Mark II Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the battery housing cover on the bottom of your camera.
    • Place a finger on the textured portion of the battery housing cover.
    • Slide the cover in the direction that the arrow is pointing.
  2. Canon PowerShot G1 X Mark II Battery Replacement: paso 2, imagen 1 de 2 Canon PowerShot G1 X Mark II Battery Replacement: paso 2, imagen 2 de 2
    • Use your finger to pivot the orange tab away from the battery.
  3. Canon PowerShot G1 X Mark II Battery Replacement: paso 3, imagen 1 de 1
    • Pull the battery out of the housing with your fingers.
Conclusión
To secure the battery back into its housing, follow these instructions in reverse order.
John Kulick
Miembro Desde 01/11/16
239 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 70-2, Forte Winter 2016 Miembro de Cal Poly, Team 70-2, Forte Winter 2016
CPSU-FORTE-W16S70G2
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 643
