Saltar al contenido principal
Canon PowerShot ELPH330 HS Camera Case Replacement
Qué necesitas
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: paso 1, imagen 1 de 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: paso 1, imagen 2 de 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: paso 2, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: paso 3, imagen 1 de 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: paso 4, imagen 1 de 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: paso 5, imagen 1 de 1
    • Using your fingers, carefully pry the case apart at the seam.
Conclusión
Michelle Ngo
Miembro Desde 07/23/19
595 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Liner Summer 2019 Miembro de UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 168
