Saltar al contenido principal
Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
Qué necesitas
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: paso 1, imagen 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 2, imagen 1 de 1
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 3, imagen 1 de 1
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 4, imagen 1 de 1
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 5, imagen 1 de 1
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 6, imagen 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 6, imagen 2 de 2
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 7, imagen 1 de 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 7, imagen 2 de 2
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: paso 8, imagen 1 de 1
    • Using the spudger, carefully pry the top to remove the LCD screen.
Conclusión
Michelle Ngo
Miembro Desde 07/23/19
595 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G3, Liner Summer 2019 Miembro de UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 462
