Saltar al contenido principal
Canon PowerShot ELPH 310 HS Shutter Button Replacement
Qué necesitas
  1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, External Panels: paso 1, imagen 1 de 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 2, imagen 1 de 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 3, imagen 1 de 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 3, imagen 2 de 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 4, imagen 1 de 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 4, imagen 2 de 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 5, imagen 1 de 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 6, imagen 1 de 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 6, imagen 2 de 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 7, imagen 1 de 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS Shutter Button Replacement, Shutter Button: paso 8, imagen 1 de 1
    • Using your hand, lift and remove the shutter button deck from the top of camera.
    • The front clasp is fragile.
  9. Canon PowerShot ELPH 310 HS Shutter Button Replacement: paso 9, imagen 1 de 1
    • Unclip the cables from the front of the motherboard, using your hands.
Conclusión
Brandon
Miembro Desde 09/24/15
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 482
