Saltar al contenido principal
Canon PowerShot ELPH 310 HS Lens Replacement
Qué necesitas
  1. Canon PowerShot ELPH 310 HS Lens  Replacement, External Panels: paso 1, imagen 1 de 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 2, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 3, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 3, imagen 2 de 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 4, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 4, imagen 2 de 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 5, imagen 1 de 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 6, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 6, imagen 2 de 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 7, imagen 1 de 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: paso 8, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: paso 8, imagen 2 de 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 9, imagen 1 de 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 10, imagen 1 de 3 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 10, imagen 2 de 3 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 10, imagen 3 de 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
  11. Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: paso 11, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: paso 11, imagen 2 de 2
    • On the front motherboard, unscrew the one bottom right 3 mm Phillips head screw.
  12. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 12, imagen 1 de 3 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 12, imagen 2 de 3 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 12, imagen 3 de 3
    • Unscrew the four 3 mm Phillips head screws attached to the metal casing on the back of the camera, behind where the LCD screen once was.
  13. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 13, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 13, imagen 2 de 2
    • Using your hands, carefully lift the flash housing up and remove it from the area.
  14. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 14, imagen 1 de 1
    • Using a plastic spudger, remove the bottom front ZIF connector.
  15. Canon PowerShot ELPH 310 HS Lens  Replacement: paso 15, imagen 1 de 2 Canon PowerShot ELPH 310 HS Lens  Replacement: paso 15, imagen 2 de 2
    • Using your hands, carefully remove the center ribbon.
    • Manually remove the lens.
Conclusión
4 personas más completaron esta guía.
Un comentario
excellent procedure. nice pix too. hint about those fragile flex cables is important, they are thinner than a human hair!
Happy Fixer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 2,551
