Saltar al contenido principal
Canon PowerShot ELPH 310 HS LCD Screen Replacement
Qué necesitas
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: paso 1, imagen 1 de 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 2, imagen 1 de 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 2, imagen 2 de 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 3, imagen 1 de 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 3, imagen 2 de 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 4, imagen 1 de 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 5, imagen 1 de 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 6, imagen 1 de 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 6, imagen 2 de 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 7, imagen 1 de 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: paso 8, imagen 1 de 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: paso 8, imagen 2 de 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 9, imagen 1 de 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 10, imagen 1 de 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 10, imagen 2 de 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: paso 10, imagen 3 de 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,092
