Saltar al contenido principal
Canon PowerShot ELPH 150 IS Card/Battery Door Replacement
  1. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: paso 1, imagen 1 de 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement, Card/Battery Door: paso 1, imagen 2 de 2
    • Safety First: Power down your camera by locating the ON/Off button on the top of the camera and holding it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 2, imagen 1 de 1
    • Locate the CARD/BATT. OPEN door on the bottom right of the camera.
  3. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 3, imagen 1 de 1
  4. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 4, imagen 1 de 2 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 4, imagen 2 de 2
    • With the backplate removed, turn the camera so that the CARD/BATT. OPEN door is face up and to the right. Press down on the door as you slide it to the right. You should hear a click which indicates that the door is unlocked and will freely open.
  5. Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 5, imagen 1 de 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 5, imagen 2 de 3 Canon PowerShot ELPH 150 IS Card/Battery Door Replacement: paso 5, imagen 3 de 3
    • With the CARD/BATT. OPEN door open, and the backplate off, gently pull the door from a 90 degree angle back towards you. Once you hear a pop ( a sign that one side pin has released), you can slide the door away from you to release the pin on the other side as well. Remove door.
Conclusión
2 personas más completaron esta guía.
Equipo
1Guía Comentario
Do you know where I can find the sensor pin for the battery door? My Elph 150 won’t turn on and I was thinking that maybe the culprit. I tried new batteries to no avail, also no power when plugged in via usb. Otherwise any ideas what could have caused it, because the camera is in mint condition.
Kimo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 24
Todo El Tiempo: 507
