Saltar al contenido principal
Canon PowerShot ELPH 150 IS Battery Replacement
  1. Canon PowerShot ELPH 150 IS Battery Replacement, Battery: paso 1, imagen 1 de 2 Canon PowerShot ELPH 150 IS Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Safety First: Power off your device. Locate the On/Off button.
  2. Canon PowerShot ELPH 150 IS Battery Replacement: paso 2, imagen 1 de 1
    • Hold button down firmly until the screen goes dark and the camera is powered off.
  3. Canon PowerShot ELPH 150 IS Battery Replacement: paso 3, imagen 1 de 1
    • Locate the Battery door which is marked, "CARD/BATT OPEN"
  4. Canon PowerShot ELPH 150 IS Battery Replacement: paso 4, imagen 1 de 1
    • Press the door down with your thumb and slide to the right until you hear a click. This means the door has unlocked and will open.
  5. Canon PowerShot ELPH 150 IS Battery Replacement: paso 5, imagen 1 de 1
    • With the door open, locate the orange clip near the edge of the camera. This clip is holding the battery in place.
  6. Canon PowerShot ELPH 150 IS Battery Replacement: paso 6, imagen 1 de 1
    • Press the orange clip back towards the back plate to release the battery.
  7. Canon PowerShot ELPH 150 IS Battery Replacement: paso 7, imagen 1 de 1
    • The battery should pop out easily and you can simply remove the battery from its housing.
Conclusión
Una persona más ha completado esta guía.
Morgan Forester
Miembro Desde 03/21/17
284 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 537
