Introducción
The Canon PowerShot D20 is waterproof and shockproof, so it won't suffer from a cracked LCD screen. However, if the camera is improperly sealed, water damage may prevent the screen from working. In this case, make sure the camera still works by taking a few pictures and uploading them to your computer, then replace the screen.
Qué necesitas
Open the cover on the bottom of the camera.
Remove the battery.
Remove the memory card.
Herramienta utilizada en este paso:Tweezers$4.99
Gently disconnect the two ribbon wires from the camera. Use tweezers or a spudger to remove them.
To remove these cables, pull them straight out of their sockets.
When reassembling, be sure you plug these cables into the sockets fully. You will hear a faint click when they are fully in.
Una persona más ha completado esta guía.
2Guía Comentarios
How do you take the shutter button part off ?
