Introducción
Have you dropped your Canon Powershot A80 once or twice over the years, and now the cover is a little loose or even coming off, making it hard to hold it steady? Have you thought about using tape (like me) to hold it on?
Great news, then this guide is for you!
Follow the instructions in this guide to help you remove and replace the front cover of your camera so you can have a better grip when taking photos and don’t have to worry about the cover falling off!
Qué necesitas
Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
