Saltar al contenido principal
Canon PowerShot A75 Speaker Replacement
Qué necesitas
  1. Canon PowerShot A75 Speaker Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: paso 2, imagen 1 de 3 Canon PowerShot A75 Speaker Replacement: paso 2, imagen 2 de 3 Canon PowerShot A75 Speaker Replacement: paso 2, imagen 3 de 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: paso 3, imagen 1 de 3 Canon PowerShot A75 Speaker Replacement: paso 3, imagen 2 de 3 Canon PowerShot A75 Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: paso 4, imagen 1 de 2 Canon PowerShot A75 Speaker Replacement, Speaker: paso 4, imagen 2 de 2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: paso 6, imagen 1 de 2 Canon PowerShot A75 Speaker Replacement: paso 6, imagen 2 de 2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: paso 7, imagen 1 de 3 Canon PowerShot A75 Speaker Replacement: paso 7, imagen 2 de 3 Canon PowerShot A75 Speaker Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: paso 8, imagen 1 de 1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Conclusión
Austin Fox
Miembro Desde 04/11/12
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-30, Amido Spring 2012 Miembro de Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 423
