Introducción
Use this guide to replace the Canon Powershot A75's speaker unit.
Partes
No se requieren partes.
  1. Turn the camera over and locate the "BATT OPEN" sliding switch.
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Slide the switch to the right. The battery cover should slide down and spring open. The battery cover should slide down and spring open.
    • Slide the switch to the right.
      • The battery cover should slide down and spring open.
  3. Remove the 4 AA batteries. Watch for the orientation of the batteries as they slide out. The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
    • Remove the 4 AA batteries.
      • Watch for the orientation of the batteries as they slide out.
      • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. Open the memory card slot by sliding it laterally until you hear a click Remove the 5.9mm screw in the upper corner of the memory card slot
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  6. Remove the two 4.1mm screws at the bottom of the battery flap.
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  7. Lift the shutter button and speaker part from the top of the camera. Do not pull the part too hard because there is a plug connecting the speaker to the camera.
    • Lift the shutter button and speaker part from the top of the camera.
      • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  8. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out. Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  9. Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Conclusión
Austin Fox
Miembro Desde 11/04/12
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-30, Amido Spring 2012 Miembro de Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 276
